I've read several posts re converting wav to ac3 for dvd useage...I was wondering what the best audio format is to use for dvd playback...if ac3 is the answer, how does one link it to the video and convert to vob...I am using vdub to strip the wav from a captured avi, then I am able to convert to ac3 in besweet...the video I encode using tmpgenc and comes out great...the reason I ask is that when I capture my video and audio using PICVideo MJPEG, the audio captures with a very high tinted noise when captured at 48Khz, when it is captured with 44.1 Khz, there is less noise and this is what I have been using for the dvd. But after I encode the captured avi in tmpgenc, the audio is not very good, I also tried capturing 48Khz and encodeing this, but the audio is worse then the 44...any suggestions on the best audio format and ways to get it to the dvd would be great. I am using Ulead DVD WS for dvd authoring.
thanks,
john
Results 1 to 10 of 10
I tried to strip off my avi into video and wav with tmpgenc and converted
the wav into ac3 with BeSweet, and authored it with tmpgenc dvd author
and dvd lab. But the resulting dvd has no audio.
Any body has any luck with the above procedure? -
OK...so your saying this would be the easiest way...that ac3 usage is not necessary...will the avi's audio get run through the engine and get encoded straight to mpg format...so there will be no need for linking later right? Why do people use ac3, anyway.
thanks
john -
This is not the same for most other countries but at least for the USA it is the DVD SPEC to have at least a LPCM track or an AC-3 track. So MP2 is officially not supported in the USA DVD spec.Originally Posted by jfharper
HOWEVER ... it does seem that most USA model DVD players can play MP2 without problems. But you never know til you try.
So to keep 100% in spec and COMPATABLE most people like to use AC-3 and truth be told AC-3 is a better format so a 2 channel WAV converted to 224kbps AC-3 will sound better than the same 2 channel WAV converted to 224kbps MP2
Very rarely does anyone use LPCM because although it can sound the best of all the formats it is not compressed and can take up a LOT of space on a DVD which limits the bitrate for the VIDEO.
5.1 Audio Question
By Simmons in forum AudioReplies: 0Last Post: 22nd May 2011, 09:12 -
audio passthrough question
By anilty in forum ffmpegX general discussionReplies: 1Last Post: 25th Apr 2009, 00:26 -
question about demagnetizing audio head on VCR to improve audio
By jimdagys in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2008, 16:47 -
Video with No Audio Question
By The Monkees in forum AudioReplies: 1Last Post: 26th Nov 2007, 18:06 -
Audio question.
By cowboysroy31 in forum AudioReplies: 2Last Post: 5th Jul 2007, 11:44
