Does anyone know if the bitsetter programs works with the OptoRite DD0203? I was thinking of getting a second DVD writer. My current one, Sony DRU510A, doesn't work with the bitsetter.
Results 1 to 9 of 9
You have a dual format burner.Originally Posted by Buck9419
Just use DVD-R instead of DVD+R
Works better anyways :P
FulciLives,
Well I was interested in the bitsetting for my older DVD player that didn't play my -r discs but does play a +RW if the bit is set to tell it the disc is a DVD-Rom. -
On some DVD+R/+RW only drives (not combo drives and not -R/-RW only drives) you can change the "bitsetting" so that the DVD is either viewed as a DVD+R or a DVD-ROMOriginally Posted by Hoagie_one
The norm is DVD+R but if you change the bitsetting to DVD-ROM then apparently it makes the disc more readable in a wider range of players.
At least that is my understanding of it.
Get some DVD+RWs(rewritables). Do full formatting.Originally Posted by Buck9419
Take them to your friend who burned that DVD+RWs as DVD-ROM.
Ask him/her to change the booktype on your discs. (5 seconds each)
Go home and burn ISO images with DVD Decrypter on your Sony(or Optorite) and the ROM booktype will survive
DVD Decrypter ISO writing doesn't touch the booktype, overwrite them as many time as you wantYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
http://www.dvdplusrw.org/resources/bitsettings.html
The above link will take you to the explanation of the compatibility settings for book type.
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
Why doesn't my imgburn program work this time?
By vladorlok in forum DVD RippingReplies: 19Last Post: 14th May 2010, 20:25 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
best sound program to work with Vegas?
By templedog in forum AudioReplies: 4Last Post: 1st Dec 2008, 13:26 -
[solved] Major MPEG2 Cutting issues. Looking for program that will work.
By ShadowBlink in forum EditingReplies: 17Last Post: 17th May 2007, 19:55
