I use IE6 and this popup came up and now its my homepage. I've gone to tools->internet options and changed my homepage several times but after a few minutes, it automatically becomes my homepage again! It's really pissing me off...anyone know how to fix this??
Results 1 to 11 of 11
1.In Internet Options select Delete Files and Clear History.
2.D/l AdAware www.lavasoftusa.com and run.
3.Check Startup and untick any Command that don't look kosher(make sure to copy the info),then go to the Registry and search for that Command and delete. -
You really should use ad aware it helps alot. Stupid Microsoft to many damn problems
Dark booty out. -
I might just do that...not being able to fix this is getting on my nerves!Originally Posted by tgpo
There seems to a problem with your link tgpo. It seems to lead to a page advertising expensive paper weights. :P
Two recomendations: Popnot and Spybot. Spybot is free and PopNot is cheap and works very well in the background.
Moviegeek gave some good advise. Ad-aware to remove spy programms.
maybe you should chek your internet settings as well.
1 open your IE6 go to "TOOLS"
2: select from the pull down menu "INTERNET OPTIONS"
3: click on the tap : "CONNECTIONS"
4: at the buttom you can see "LAN SETTINGS" klick on this one
*:now you are in the window "Local area Network (LAN) settings"
you can see 2 options
1: automatically detect settings
2: use automatic configuration script !!!!!!!!! this is the ONE!!!!
if the automatic configuration script is tagged (you can also see the site below) de-select this option. klick "ok"
5: go back to internet options->general: insert your favourit home page again.
cheers,Why is the universal question why? -
Thanks for all the suggestions...moviegeeks advice didnt work the first time but I tried it again and now I have the problem fixed.
