Hi, I have succesfully converted an avi media file to a svcd mpg file and my intention was to cut it and put each half on a CDR.
In TMPGenc I select Tools/Merge and Cut to a MPEG2 SVCD file. I cut the file in half (ish) and then click on Run. It produces an audio and video file, then starts to multiplex, but after about 70% TMPGenc tells me thare was a stream writing error.
I used TMPGenc to convert the file so why should it produce this error?
How do I cut the 1.6Gb file in half now?
Bob Heselwood
Stream writing error can sometimes suggest you've run out of disk space. Are you sure there is enought room on your hard drive ?
1) its easier to use the source range option in tmpgenc to encode each half of the movie, rather then cutting the whole thing.
2) Womble MPEG2VCR is a real good cutter.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
Aegisub wont play mpg, converting using divxland causes problems
By denadel in forum SubtitleReplies: 2Last Post: 2nd Oct 2011, 05:36 -
Final Cut Pro imports .MPG's with no audio.
By Benhermies in forum MacReplies: 2Last Post: 20th Sep 2009, 17:09 -
How can I cut out an image from a mpg file? Just one frame
By szalaikornel in forum Video ConversionReplies: 4Last Post: 28th Jan 2009, 11:59 -
cant trim/cut mpg in QT-pro
By Kevlin in forum MacReplies: 3Last Post: 17th Aug 2008, 14:25 -
Final Cut wont capture
By Rich W in forum MacReplies: 3Last Post: 24th May 2007, 09:40
