When I run a particular video file throught DVD2SVCD everything runs well until it gets to %60 of the Cinema Craft Encoding. I am running DVD2SVCD 1.2.1 Build 2 and CCE 2.5.
Any light you could shed would be great!
Here is what Gspot tells me...
Here is what the encoder looks like when it freezes
Here is the log file from DVD2SVCD
Bitrate failed,0.00
WNASPI32.DLL 4.6.0.1021
- 14/10/2003 9:46:18 AM
- AVI to SVCD Conversion
- AVI2SVCD ver. 1.2.1 build 3
Initializing
- D:\eric\dvd\101-103.avi
Initializing finished.
- 14/10/2003 9:46:21 AM
- Free on drive C: 953.21 mb
- Free on drive D: 10777.43 mb
- AUDIO Extraction
Audio extraction finished.
- 14/10/2003 9:47:19 AM
- Free on drive D: 10684.59 mb
- AUDIO conversion
- 14/10/2003 9:47:20 AM
- Free on drive D: 10684.58 mb
- AUDIO conversion
Encoding Audio. Filename: D:\eric\dvd\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Program Files\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "D:\eric\dvd\Extracted_audio_1.ac3" -output "D:\eric\dvd\Encoded_audio_1.mp2" -logfile "D:\eric\dvd\Encoded_audio_1.log" ) -azid( -L -3db -l 0db -c normal -s surround -g max ) -shibatch( --rate 44100 ) -2lame( -e -b 192 -m s )
Audio conversion of D:\eric\dvd\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 14/10/2003 10:03:55 AM
- Free on drive C: 917.65 mb
- Free on drive D: 10591.73 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 833934864
AudioSectors: 98793240
VideoPAPO: 11387736
ScanOffsetBytes: 116708
SeqAligningBytes: 7417467
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 1.00
PureMPEGStream: 716219708.40
Seconds: 4061.43
CalcMPEGStream: 716219708.40
Frames: 97257
CDSize: 800.00
Number of CDs: 1
Cut point 795.00
Variable Settings:
Frames: 97257
Anti Noise Filter: Off
Passes: 5
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 1410
Aspect Ratio: 4:3 (No borders, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\DVD2SVCD\AVISYN~1\Mpeg2dec \mpeg2dec.dll")
AVISource("D:\eric\dvd\101-103.avi",False)
ConvertToYUY2()
BicubicResize(480,480,0.0,0.6)
Import("C:\Program Files\DVD2SVCD\Movie\ResampleAudio.avs")
ResampleAudio(44100)
----AVS End----
I'll take a look at this in a little bit, but I just wanted to pop on here and say, "awesome job" for providing information with your question. I wish more posters were like you. So many use to the subject line "help" and the question being something totally vague.
Hopefully, someone else can answer this quickly for you if I cant. I just had to comment on it. That and you are a realitively new to the board. -
Open that avi-file with virtualdubmod and chooce VIDEO -> Direct stream copy. Audio -> Direct stream copy. Then just save it with different name. That could help if the avi-file is corrupted.
One piece of information that I forgot to mention was the fact that I combined the avi from three different files using Nandub 1.0rc2 build 1853. There was no eror msgs and it worked flawlessly. I also used VirtualDub before the NanDub step to ensure that the avi's used didn't have any errors.
Thanks... -
You could try this OPV method:
http://www.mpegit.net/eng_svcd.php
MEGui FREEZES!!
By mark63534 in forum Newbie / General discussionsReplies: 0Last Post: 23rd May 2010, 20:43 -
AVI Freezes up
By surffx in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2010, 05:49 -
XP freezes momentarily
By sdlehman in forum ComputerReplies: 12Last Post: 11th Aug 2008, 16:01 -
how to filter away freezes ?
By cyflyer in forum MediaReplies: 3Last Post: 24th Feb 2008, 16:51 -
Vcd freezes
By notebookguru in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Dec 2007, 15:00
