  1. I was wondering if it is possible to make a dvd using my own selected clips from dvd's and to include my own song on it.
    if anyone can point me in the right direction.
    thanks
    May 2003
    Pal Realm
    Yes. It's possible. The pointer is to first learn to rip form the DVDs, then Convert, then Author.
    If you start at DVD Rip Guide on the left, that'll be a good diving in place.
    Skip that if you already know how to rip. :c)
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
