im looking for the fastest encoder for encodeing to dvd mpeg2, so wot do u guys recomend
get a faster cpu first
Originally Posted by liquiddecay"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
You don't really give enough info.
A faster is not always a better answer. For example, a transcoder is faster than any encoder if you go from mpeg2 to mpeg2. Faster but bad quality is not a good thing. If I cut an encode from 12hrs to 4hrs it really doesn't matter. I sleep at night and then go to work. So only if I do batches or I go to say 1hr would I say wow.
What do you use now? TMPGEnc. What have you looked at? CCE $70, MainConcept $150? How about a DVD recorder? Capture + Encode + Burn in real time.
How fast do you want?I mean it in the nicest way.
Whats the fastest video encoder?
By groggit in forum Video ConversionReplies: 25Last Post: 14th May 2013, 11:14 -
which is the fastest encoder no matter output format
By gyzel01 in forum Video ConversionReplies: 30Last Post: 17th Nov 2011, 04:20 -
Whats the fastest FLV encoder?
By last_registered_user in forum Video ConversionReplies: 0Last Post: 9th Sep 2009, 22:17 -
Best and fastest way to convert episodic DVD episodes to MPEG2?
By Y2Bogus in forum DVD RippingReplies: 2Last Post: 4th Mar 2009, 13:20 -
Fastest but good quality mpeg-2 encoder
By cd090580 in forum Video ConversionReplies: 12Last Post: 23rd Jun 2007, 11:42
