A strange thing occurs since V0.0.9.
You specify a specific video size, in my case 352 * 400, Autosize 16:9 for example, and the resulting mpeg doesn't match this size. In my case, in become 720 * 404.
Source is 720*576, export from imovie in Expert settings - DVCPRO format.
It seems to me that this problem came already with previous version of ffmpeg, but only for fast mpeg1 encoding.
Exact control on output size is needed, for example to get a resolution that will match exactly my 16:9 TV and avoid a bad ratio for the image.
Bug or feature ?
Pierre
Pierre DucheneGuest
Pierre DucheneGuest
Unfortunately, this doesn't works.
I'm sure, because I drop the file once.
After this, I made a try with one resolution.
Next another try (since the produced MPEG didn't correspond), next another, and another. (Each time adjusting parameters... one at time).
Please try. I insist : this is a new behavior since v0.0.9.
In 0.0.8a it still works perfectly.
Pierre
Pierre DucheneGuest
After private email exchange between Major and me, it appears that size is finaly correct.
It is Quicktime Player who report an incorrect size.
To verify this fact, I simply drag the generated mpeg file on ffmpeg icon, as Major suggested me.
In the "info area", the correct size (the one I specified for conversion) IS shown.
However, it is strange that this occurs every time with V0.0.9, and never with previous version.
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 07:30 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
Converting from VOB to any other format - doesn't keep the original size
By Mylo in forum DVD RippingReplies: 5Last Post: 14th Mar 2009, 13:58 -
Avi to DVD (mpeg2enc), doesn't fit screen (noob)
By bilboshaggins in forum ffmpegX general discussionReplies: 7Last Post: 14th Dec 2008, 14:53 -
VOB to MPEG1 (mpeg2enc) Failure
By speedreader in forum ffmpegX general discussionReplies: 7Last Post: 1st Aug 2007, 20:07
