I just got my Pioneer 105 exchanged to a 106 because of a failure.
My 105 ate almost anything u feed it with (even loafs of bread)
But my 106 seems to be a little picky.. its spits out my Princos and Datamart DVD-R - even at 2 speed burn - and its coasters. This only happen when i try to dvd burn.
Anyone got any idea
Nother question about setup.
1 got 1 250 Maxtor HD as main HD - 2x200 MB MAxtors on a raid controller (for storage) - and an asus DVD and my Pioneer 106
What would be the best cable setup for main hd and the 2 dvd's ?
T.I.A.
Results 1 to 11 of 11
Have you updated the firmware? The latest firmware makes the 106 more compatable with cheap media.
YES -unfotunately - i upgraded to 107 - and i cannot downgrade again
(not any way i know of) - arrrrgh -
Put your HD as Master on the Primary IDE channel, the 106 as Master on the Secondary IDE channel and the DVD drive as slave on the Secondary IDE channel. Make sure that DMA is enabled on all of them.Originally Posted by xboxnoob
cheers
Looked for the DMA (like in win 98 ) - but - well - no dma checkboc in xp pro -
In Win XP Pro, go to Device Manager, select IDE ATA/ATAPI Controllers, select Primary IDE Channel, select Properties, then Advanced Settings. Make sure DMA If Available is set. Do the same on Secondary IDE Channel.
DMA enabled. -
Might work for you - but i got no advanced tab setteings or other..
b.t.w. its a Intel 82801DB Ultra ATA Controller -
Huh?? I'm using AMD processor with VIA chipset running XP Pro SP1 and in Device manager under IDE ATA/ATAPI controllers, I have 3 entries. They are Primary IDE Channel, Secondary IDE Channel and VIA Bus Master IDE Controller. I would expect yours to be identical except for the last one which would show your Intel controller instead of my VIA one.
The important bits are under the first two, not the chipset controller entry. -
I know what you mean - no prob there.
but om my first and second ide channels - there are no advanced tab - nd no place to set dma on or off - im using a MSI MB - and get Intel utility so i can watch alot of the stuff on thé MB - including ide channels - and it syas dma support in there - but no turn of or on ... so different types of ide controllers - different handeling i guess. -
But my 106 is still Picky like hell... i managa to make my first - FIRST IN 5 DAYS "non-coaster" today - on a Verbatim+media (4 speed)..
Really hope the bulpaqs and Riteks i ordered will help me out -
You must have the Intel IDE drivers installed. They automatically enable dma mode.Originally Posted by xboxnoob
LITE-ON iHES 106 BD-ROM + PowerDVD 8 cannot play Blu-ray disc
By eppingwest in forum Software PlayingReplies: 2Last Post: 23rd Apr 2010, 14:51 -
Showbiz DVD2 vs 2.2.15.106 vhs capture problem
By zulubase in forum Capturing and VCRReplies: 0Last Post: 13th Feb 2010, 19:28 -
Pioneer DV-F727
By captainneek in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jan 2010, 14:59 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Pioneer dv-400k
By markarcade1 in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2008, 15:44
