Results 1 to 9 of 9
  1. I am wanting to convert an AVI onto a DVD, as i have never done this beofre can you please help.....
    Live Your Life To The Full !!!!!!
    May 2003
    Pal Realm
    Best place to start is with the Guides available to you on this site.
    Have a quick read through What Is DVD and then move on to convert.
    If you see terms you're unfamiliar with use the Glossary.
    Any specific questions as you're learning, post again with that question.
    Lots of reading to do. Get cosy.
    Good luck. Have fun. :c)
    There's no place like 127.0.0.1
    The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts.
  3. I cannot help, I am only a captain guide
    The electronic components of the power part adopted a lot of Rubycons.
  4. i have had a read of the site but i do not understand most of it, can any one please recomend any good programs to convert AVI's to DVD's
  5. you can use TMPGEnc to convert the avi to MPEG2 (use the DVD NTSC template) u can get a free trial, MPEG2 enabled for 30 days, but youll have to use guides to deal w/ audio, and to make sure it fits, adjust quality, etc.
    Oct 2003
    deep in Wonderland.
    What don't you understand? You need to be a lot more specific about your problem. If there's a term in the guide you don't know, check the glossary over to your left. If you don't understand the guide, then tell us exactly what it is that's throwing you off. If you're looking for a one-click program that will take your avi and make it into a DVD, you probably aren't going to find it - *especially* if you're working with files that you downloaded. DVD's are *not* super-easy to make and *will* require a little work on your part (no matter what the box your burner came in says.) Do a little more reading and let us know where you're stuck - then you'll get more precise answers.
  7. download dvd2svcd
    download divx codec pack
    download xvid codec
    purchase TMPGENC,CCE, or procorder
    on misc. tab, press avi radio button
    check mark advanced tab
    go to frameserver tab, click dropdownbox and select dvd resolution (better off trying CVD one though)
    click on encoder tab and select the encoder you purchased and locate the path to it
    click 1 pass CBR
    click tab next to misc tab and open avi file
    click run and then OK
    wait XXXXXX hours
    purchase dvd authoring program
    pull in resulting mpegs into program
    author
    burn on dvd burner
    watch
  8. Member Webster's Avatar
    First read this guide:
    https://www.videohelp.com/tmpgencdvd.htm
    Then go here and read on how to author DVD
    https://www.videohelp.com/author.htm#dvd
    Come back and ask questions (After you have read and tried it once) if you run into problems.
    Webster.
  9. Thank for your help guys it is now workin
