I need to convert my flash presentation file to VCD. So I export the movie from Flash to Avi. Then using the TMPGEnc to convert it to MPEG file. After conversion, I can view this MPEG on my PC. So I used my Sony CD Burner software to convert it to VCD. When I put the CD in my VCD player, it cannot be played at all. Please help.
Results 1 to 11 of 11
In what speed did you burn it..?
Never burn higher than 4x on VCD...
Magnus Jensen
A.K.A Geezus -
Thanks KuskenLars. But I've just tried to burn it at 4X speed and it still won't help. The VCD just cannot detect or play the CD at all.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
I've tried using Sony CD MAKER 2000 PROFESSIONAL AND NERO 5.5, still not successful. I've already made lots of coasters, pls help.
What DVD player do you have? And the reason for suggesting a CDRW is that there are a number of DVD players that don't read CDR, but do read CDRW.
Mine is a Samsung VCD player not a DVD player. If I used the PC MSI DVD player, no problem. I've tried others CDR, it can played on my VCD player too.
Why? I burn VCD's at 8x all the time.
Some players have problems with CDR's burned at higher speeds than 4x...
Magnus Jensen
A.K.A Geezus -
Try a different encoder... flash mpeg or something. Then use nero's vcd option. It tells you if a vcd will be compliant when you burn it. If you try to import a file that's not compatible... it stops you.
VCD Karaoke (MPEG DAT file)- removing the vocals
By tsrusa2002 in forum Video ConversionReplies: 12Last Post: 22nd May 2011, 03:51 -
One hour, 37min AVI file that I want to turn into a VCD
By penang in forum Newbie / General discussionsReplies: 23Last Post: 17th Feb 2011, 11:11 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Pioneer DV-400 - avi/mpeg off flash drive?
By snowverkill in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Jul 2007, 19:11
