  1. When I open vfapi converted d2v in adobe set my resize and output to the cce 2.50 plugin the framerate is default 1 fps and is ghosted so I can't edit it I tried everything I can think of but it won't let me change the frame rate, the problem is not there when i use panasonic encoder it allows me to change all seetings.......any ideas???
    Apr 2001
    Netherlands
    Got the same problem, the developers of CCE are warning for a discompatibility with adobe premiere 6.0 (it seems to work fine with 5.1.
  3. ok thanks maybe i'll down grade
  4. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    The crack wasn't written correctly. The full bought version works fine with Premiere 6. There's a hack for the crack floating around that fixes this, search these forums and you might find the links to it. You have to use a hex editor to edit one key. They explain how to do it pretty clearly, but I haven't heard if the hacked crack works or not, but the full version works fine.
