  1. I've been experimenting with the new "Join" feature in DVD2oneX 1.2.0, working on the flipper DVD "Amadeus".
    I'm selecting the AC3 6ch audio stream (music and dialog) and the AC3 2ch audio stream (music only) when joining both sides of the DVD into one single-sided DVD.
    When the resulting DVD is played using the Apple DVD Player application or in my stand-alone DVD player, the "music only" soundtrack comes up as the default -- I have to change to the alternate soundtrack using the DVD Player controls or the stand-alone player's remote to get the "music and dialog" soundtrack.
    Is there any way in DVD2oneX that I can select which audio stream becomes the default soundtrack on the final DVD?
  2. Originally Posted by Ladd
    Answering my own question, with info received from the DVD2oneX forum:
    Double-click on the audio stream you wish to be the default. An arrow will appear to the left of the audio stream listing, acknowledging that it has been selected as the default.
