  1. ive got a kvcd that is not playing right in windows, it starts of ok, then the movie stops but the audio carrys on, then it all catches up, then its ok for a couple off mines, then it starts all over again. could it be that i need some sort off codec for it?
  2. Could be your player has a problem with 23 fps, which the kvcd templates are based on. Best place to ask would be www.kvcd.net, and ask Kwag about it.
  3. re burn as std svcd or vcd and see if that works any better.
    The electronic components of the power part adopted a lot of Rubycons.
  4. no its not palying on my pc i.e media player, i tryed to convert it to dvd with tmpeg but even then it was still playing funny
