  1. http://www.mediachance.com/dvdlab/history.html
    Version 1.3 BETA 4 (download dvdlabup13beta4.exe (4.2 MB) - you need to have installed at least full 1.1 version)
    Mainly fixes before release
    - Menu Count issue fix, now you can have 254 menus (previously only first 127 were accessible)
    - ability to link end of the movie with one of the first 63 menus. Now you can link end of the movie to a movie, slideshow, a menu or use RET to return to last opened menu.
    - PAL highlight yet another fix. While still not sure what is the root of the problem, this may help
    - fix muxer for high bitrate video and pcm
    - fix for frame indexing prior compile
    - fix supporting some rare mpv files
    - fix for displaying transitions in connection from previous version
    - fix Export chapter Save dialog (extension missing)
    - Panasonic VRO files will now not offer demuxing or joining, the correct import is without demuxing so no choice will be given.
    - Fixed Trim end if trimming above 2GB (infinite loop)
    - Improved reading of mpeg total time
    - Improved adding chapterpoints to some messed-up vobs.
    - Added support for 96/24 PCM audio
    Oct 2002
    Thx for the news, went to the site yesterday looking but they must of posted the update later.
    Nice one.
