Hi all,
i have a plextor 24/10/40A and have burned countless numbers of CDRs . however, was recently have way through burning a CD anfd had to re set the computer. this seemed to have disturbed my CDRW drive and it now takes twice as long to burn a CDR! it used to burn a whole cd in 4 mins, but now it takes 8! i remember having had this problem a few times before and a simple reinstall of windows fixes it. however, i dont want to go through all this hastle again.
when burning iwth nero i can see the burnewrs buffer level is constantly flucuating from 98% to 10%, which would explain the change in burning time. i have tried reinstalling the IDE drivers (im using win xp so just uninstall in device manager & restart PC) but this hasn#'t helped. i have also physically removed the drive having uninstalled the drivers, booted, shut down and then reconnected the drive but this hasn't helped either! anywayone have any ideas? any advice/help would be greatly appreciated!
1)Why Not Overclock a little?! speed 4 free!!!!
2) If your question has anything to do with copying PS2/PC/XBox games, find a more appropriate website -
defrag ?, are you only running your burning program ?, is this happening in all burning progs or just 1 ?
tried defrag, doesn't help, using Nero- havn't tried it with others but have uninstalled/reinstalled it, happens with several or just nero running, im running a 2500+ so unlikely to be CPU intensive! thanks all the same man!
i have the same problem and im unable to fix does anyone know how to fix it.
thanks
Imgburn device buffer showing -6506% when burning dvds.
By xoADAMox in forum Newbie / General discussionsReplies: 0Last Post: 24th Jun 2010, 20:32 -
YouTube Buffer Speed
By gooberguy in forum ComputerReplies: 4Last Post: 25th Feb 2010, 21:12 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
the best burning speed for DVDs
By JohnnyBob in forum Newbie / General discussionsReplies: 13Last Post: 15th Jan 2008, 08:50 -
what is a good burning speed???
By offensekilla in forum Authoring (DVD)Replies: 6Last Post: 29th Aug 2007, 01:08
