Sorry if this one's been addressed already...
WTF does "could not opening output stream" mean as a terminal error in VCDimager? I've been trying to use the TSCV GUI to burn SVCDs, or having it generate a base xml document that I edit to get VCDs (the GUI doesn't seem to support VCDs w/ the current version; the option is greyed out). However, every time I try to make a .bin file, I get that same error at the end. I'm encoding my video files using TPMG encoder's standard templates.
Can anyone clue me in as to what I'm doing wrong or what this error message signifies?
Results 1 to 1 of 1
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 22:48 -
After Effects error: opening sound component (-2166)
By santolina in forum EditingReplies: 0Last Post: 24th Apr 2010, 09:36 -
error when opening up mkv file with virtualdubmod
By parth82390 in forum Video ConversionReplies: 5Last Post: 5th Dec 2007, 19:00 -
Error message popup when opening folders with vids
By majax79 in forum ComputerReplies: 32Last Post: 26th Sep 2007, 03:31 -
Error when opening avs in VirtualDubMod
By chrishallowell in forum Newbie / General discussionsReplies: 6Last Post: 28th Aug 2007, 08:57
