Hi all,
i have been making CVD for some time now but the audio on my movies is always feint! i have to turn up the volume significantly more than if im watching a dvd or listening to music. it is not the player as this occurs with Windows Media player and also Power DVD. im ususing standard SVCD settings, with an audio bit rate of 192KBPs
i wonder whether there is a simple way to "boost" the audio without interference (other than turning up volume lol!)
Im using the latestst version of DVD2SVCD and CCE 2.50, although i have had this problem in the past with previous versions of DVD2SVCD!
any ideas/suggestions would be greatly appreciated!
1)Why Not Overclock a little?! speed 4 free!!!!
2) If your question has anything to do with copying PS2/PC/XBox games, find a more appropriate website -
I know if you use TMPGEnc you can boost your audio before you convert it. I know when I used it I had to bump it up to 200% to get normal audio levels for my movies. I've never used DVD2SVCD. I just downloaded it and it seems a little confusing. I personally like TMPGEnc and Nero for VCD/SVCD Burning. Just my .02¢
Recovering quiet audio
By ReedJohansson in forum AudioReplies: 6Last Post: 20th Mar 2012, 05:03 -
VOB2MPG Quiet Audio
By gfinlay in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Apr 2010, 03:28 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 04:57 -
Captured audio low/quiet/soft
By binister in forum AudioReplies: 1Last Post: 1st Dec 2008, 11:18 -
Front panel audio gone quiet all of a sudden
By specane in forum AudioReplies: 8Last Post: 5th Aug 2008, 10:02
