I made an audio CD out of a DVD and was wondering if there is any software that would still insert (or keep) the track number without a gap or click between the tracks. Some original CD's are like this where two tracks (or songs) are like track 1 and track 2 but are joined together so there is absolutely not interruption in the music.
I found this in my database of intresting shit to save for boldego :P
When you write a CD out, the individual tracks have a space between on them referred to as pre- gap. The length of this gap depends on what format each of the tracks is written to. For example, a CD- ROM data track followed by a CD-ROM XA tracks needs to have a 3 second gap between them. How big the gap needs between tracks needs to be depends not only on the track format but on how the disc is written; some of the gaps can be written smaller if the disc is written in disc-at-once mode, where the entire CD is written in one pass without pausing. If you have an audio track followed by another audio track, as you typically would on a regular audio CD, there is no gap between tracks when using disc-at-once mode. But if you write using track-at-once mode instead, there is a 2 second long gap between every audio track that you have no control over. In order to properly create audio CDs that have transition between tracks without a pause, you configure the software to use disk-at-once mode (and, I'll mention again, have a drive that supports that mode of writing). try it !
Thanks. I'll try it right now as soon as i see it DOA is an option in my software.
Holistic
That did the trick. Don't ever delete that data base of yours!!!
Annoying 'gap sound' when joining flv files
By KeyMs92 in forum EditingReplies: 2Last Post: 17th Sep 2011, 19:31 -
Automatically reducing the gap between subtitles
By Niggylefrançais in forum SubtitleReplies: 2Last Post: 10th Jul 2011, 09:48 -
GIMP GAP Green Frames
By mixt in forum Newbie / General discussionsReplies: 9Last Post: 25th Apr 2011, 08:45 -
Camcorder video of ice hockey - gap stitching
By p9g in forum EditingReplies: 2Last Post: 24th Oct 2008, 06:13 -
how to bridge the gap between my digital camera and my home DVD player ?
By Dilermando in forum Newbie / General discussionsReplies: 5Last Post: 7th Oct 2007, 03:19
