I'm having problems getting my LG GDR8161b DVD Rom (v102 firmware) to recognise DVD-R disks. It will play commercial DVD's (Region 1 and 2) and DVD data disks OK, but will not recognise a DVD-R that I have burnt in my Optorite DD0203 writer (v2.16 firmware).
The drive doesn't recognise that a disk has been inserted.
I'm using Win XP Pro SP1, and don't have ASPI installed. I'm ripping and burning using Clone DVD (various versions inc latest) and have AnyDVD enabled to remove region protection. All the DVD-R's will playback on the Optorite drive and on my PS2. I use Power DVD 5 to playback on the PC.
Nero infotools tells me that the LG drive should recognise DVD-R media (but not DVD+R) which is correct. The medium I'm using is Bigpockets own brand 4x (datasafe manufacture).
I'm stuck. Any ideas ?
Thanks anyway, but I've just found out from another source that the Optorite drive is the cause of the problem.
Apparently the Optorite DD0203 produces DVD-R that cannot be read on PC DVD ROM's, although they work fine on standalone players.
The word "lemon" springs to mind !
JVC DR-MH30 DVD drive mechanism compatibility
By MacMater in forum DVD & Blu-ray RecordersReplies: 5Last Post: 30th Dec 2011, 01:36 -
DVD skipping problem. Slow drive speed.
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Jan 2010, 15:37 -
problem with my cd/dvd-rw drive or with nero or both!
By NBABE1 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2008, 13:20 -
problem burning with external dvd drive
By billybob59 in forum DVD & Blu-ray WritersReplies: 15Last Post: 8th Mar 2008, 19:32 -
Help! My DVP5960 has compatibility issue with Seagate FreeAgent 500GB drive
By agidol in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Dec 2007, 08:50
