I'm checking with the 0.8d version, just for basic encoding for home videos to mpeg.
Now I'm trying to do all the process with ffmepgx. I use the ffmpegx engine to encode, and demux + remux with tmpgenc to ensure dvd playing. (The ffmpegx encoder works fantastic, but it's incompatible with my dvd player)
I'll get the videos with a capture card with the PC. I'll never with the same mode, just to check how to improve the capture. Then, I'll left in the mac and encode with ffmpegx.
Well. I've the same problem with the two last avi...no sync with audio and video in the dvd? I cannot understand, because the first two that I encode to mpeg1 has no problem!.
Any suggestions?
I have checked this:
https://www.videohelp.com/forum/viewtopic.php?t=157700&highlight=sync+mpeg1
Pix wrote:
-It is not fully VCD compliant : depending on the player, you get randomly not in-sync sound, which re-syncs if you press "pause" and "play" again
- I saw the sound is 48000 hz instead of 44100 which is in
the standard : by demuxing and remuxing with a 44100 hz mp2, does it make it VCD compliant ?
Major wrote
- If source is a DVD then 48Khz leads to better sync with the ffmpeg resampler, though not standard, many players accept it.
It could be a solution to demuxing and remuxing with a 44100 hz mp2?
The best solution is to re-encode it with 0.0.9. If you want to fix previously encoded material, please email me to major4@mac.com with details on your files, formats, process output, etc. and I'll try to help you.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 04:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 16:17 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05
