I have a problem in joining 2 avi files as they have 2 different audio sample rates and i cannot find the guide 2 help me.
normally i:
join avi with vdub
strip wave with vdub
convert to mpeg2 with tmpgenc
author dvd with tmpgenc dvd
burn.
run the files thru virtualdub and choose direct processing for video and full processing for audio for both,then join
thanks for reply
do i save video as direct stream copy
what do i save file as ? -
save as direct stream for video and full stream for audio then open the first file with virtualdub then open the second avi file as append avi segment and then save as anyname.avi with direct stream for video and full stream for audio
What you're doing is saving new avi's with wav audio. You should be able to join them after that.
If not, then you need something like Goldwave to create wav files from the audio. Re-load the wav files back into each avi and try joining them again."Art is making something out of nothing and selling it." - Frank Zappa
joining avi files
By dugen in forum MacReplies: 1Last Post: 11th Jun 2011, 12:47 -
Joining avi files
By carlmart in forum Video ConversionReplies: 13Last Post: 29th May 2009, 07:35 -
Joining AVI files
By nycdude in forum EditingReplies: 6Last Post: 20th May 2009, 23:03 -
Joining avi files?
By tofuguy in forum EditingReplies: 4Last Post: 7th Oct 2008, 02:30 -
Joining avi files?
By t_jay17 in forum EditingReplies: 5Last Post: 18th Dec 2007, 12:22
