I'm currently having no success in getting my DVD ROM drive to recognise DVD-R discs. The drive is an LG GDR8161b with version 102 firmware (latest). It recognises and plays commercial DVD's (region 2 and Region 1) without a problem (it also handles data DVD's perfectly). However it won't play DVD-R's recorded on my Optorite D0203 writer.
I'm ripping and burning using the latest (October) version of Clone DVD and I have AnyDVD enabled to remove region protection. (I've tried disabling AnyDVD, and switching to safe mode). I'm playing using Power DVD 5, but the software isn't the problem as the drive just doesn't recognise that a disc is inserted.
The same DVD-R discs play in the Optorite and on my PS2.
Nero-info tells me that the drive should be able to read DVD-R (but not DVD+R) which is correct.
In using Win XP Pro SP1, and I don't currently have ASPI installed.
I'm stuck. Any ideas ???
Results 1 to 1 of 1
JVC DR-MH30 DVD drive mechanism compatibility
By MacMater in forum DVD & Blu-ray RecordersReplies: 5Last Post: 30th Dec 2011, 02:36 -
DVD skipping problem. Slow drive speed.
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Jan 2010, 16:37 -
problem with my cd/dvd-rw drive or with nero or both!
By NBABE1 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2008, 14:20 -
problem burning with external dvd drive
By billybob59 in forum DVD & Blu-ray WritersReplies: 15Last Post: 8th Mar 2008, 20:32 -
Help! My DVP5960 has compatibility issue with Seagate FreeAgent 500GB drive
By agidol in forum DVD & Blu-ray PlayersReplies: 4Last Post: 26th Dec 2007, 09:50
