When i load a avi file, sometimes i get this error message
"couldnt locate decompressor for format MPG4.
virtualdub requires a video for windows VFW compatible code to decompress video. directshow codecs such as those used for windows media player are not suitable"
what does it mean and how can i get the codec it asked for
thanx
If you are using MPG4 V3, then virtual dub won't open it or encode. MPG4 V2 will work. Microsoft has some anal retentive thing with their MPG4 V3 codec that only allows it to be used with ASF's.
I think you will find the Kristal Codec pack in the 'tools' section here will get you past this one. (not guaranteed but worth a few minutes to try out.)
Good luck,
Ian -
The Mpeg4 V2,3,4 codec is available, take a look in the usual places, if you don't fine it let me know.
I had no problem downloading it from grokster,kaza etc along with fast and slow motion, smr and 3.11 alpha.
_________________
___
___
<font size=-1>[ This Message was edited by: letmeinforgodsake on 2001-10-09 14:25:38 ]</font>
Problems re-using VirtualDub
By djdust in forum Newbie / General discussionsReplies: 17Last Post: 27th Apr 2011, 08:57 -
.mkv problems in Virtualdub
By alc112 in forum Video ConversionReplies: 14Last Post: 10th Feb 2010, 23:47 -
virtualdub dv type 2 problems
By sander815 in forum Video ConversionReplies: 26Last Post: 21st Nov 2009, 19:58 -
Problems with Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 09:23 -
A couple of VirtualDub problems.
By Rein Engel in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2007, 03:07
