Real simple, and I did do a search and read alot of stuff but I have to ask it so I know I under stand it.
I took a home video and put it on DVD I encoded at 4:3 / 720x480, now on my PC it looks fine when I play it on Power DVD, but when I put it in my DVD player for the T.V. it goes beyond the limits of the screen.
I read some people saying to subtract between 5-10% from the size you have to adjust for a T.V.
I have a 29" T.V. I formated under NTSC standars.
Is there a simple rule of thumb for doing playing on my T.V.? TIA
https://www.videohelp.com/glossary#Overscan
720 * 5% = 36 pixels on each side
480 * 5% = 24 pixels top and bottom
Just know you will not see and take it into account when you frame the shot.
If you want, you can resize your current video to 648x432 and then add a black border to make it 720x480 again. This will be a pain if you have interlaced source (ie from a dv cam), especially if you are picky.
I mean it in the nicest way. -
Ok I have Captured video off of my Digtal Camcorder, I used Abobe premiere to add transitions and effects, now do I have to use another program to add the black bars?If you want, you can resize your current video to 648x432 and then add a black border to make it 720x480 again. This will be a pain if you have interlaced source (ie from a dv cam), especially if you are picky.
Need basic info on Simple profiles when capturing video with XviD codec
By snafubaby in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 22:54 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
Simple MKV file and info given -Need it in AVI
By cyberlion in forum EditingReplies: 2Last Post: 15th Aug 2010, 06:29 -
A simple trimmer for real media files
By kutchbhi in forum Newbie / General discussionsReplies: 7Last Post: 22nd Sep 2009, 08:29 -
HD DVD .EVO to .MKV (I need a real simple method)
By craig198 in forum Blu-ray RippingReplies: 0Last Post: 26th Aug 2008, 14:24
I don't know premiere.
