  1. I want to add a musical background to an MPG2 video clip before I burn it to DVD
    I have Tmpge, Adobe Premiere, and some Ulead programs
    I tried TMPGE (the program I used to strip the sound, and cut the videos up and then emrge them, but it says it's an invalid format) I also have Cool Edit, so I could possibly change the sound clip to a compatible format if thats the problem?
    Any help would be great!
    Apr 2002
    The State of Frustration
    Telling us what kind audio format the file you are trying to add would be "greater".
    Hello.
  3. Originally Posted by Tommyknocker
    Any format I have to. Right now it's MP3 or WAV
    It does not matter. I just need to know what format I need to have the sound file (I can then use Cool Edit to change it to whatever format I need to), and WHAT PROGRAM I can use to add the audio to the video clip
    Anyone?
    Apr 2002
    Using TMPGEnc, load your video as Input Video, and your wave file as Input Audio. Select your template, name your output file and press Start.
    Hello.
