I have a lot of digital photos that I want to store and hopefully keep for a long time. I just got a multi-format DVD writer and my dilemma is: shall I write in DVD-R or DVD+R? After you write a DVD, is it simply a DVD and will play in any DVD-ROM, or is it forever a DVD-R or a DVD+R? My fear is that I will archive my work on DVD and in just a couple of years, the format will be extinct? Which format shall I use? Any suggestion would be helpful.
You will have to do what we all do keep copying to new formats...just like VHS to VCD and now DVD-R.
Regards -
After written, it (+ or -) will be readable in any DVD-Rom.
Well god knows there are probably some really old units out there that were made before DVD+R, so any is a strong word. So let's say 99.9%.
This info is under "What is DVDr"
[edit] You should be more concerned about high quality media and storage of it. The other day, I had to use 4 different drives to try to recover data from a cdr. My newest drive (the dvd burner) did the trick.I mean it in the nicest way.
best format and size to convert a vcd dat file to for archiving?
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2012, 04:59 -
Archiving DVD Collection
By jkellier in forum DVD RippingReplies: 2Last Post: 2nd Jun 2010, 17:55 -
Suggestions for archiving HD to DVD-R media
By PartingShot in forum ComputerReplies: 1Last Post: 11th Feb 2010, 13:58 -
Archiving TV eps on DVD
By bdizzle in forum Video ConversionReplies: 2Last Post: 17th Nov 2008, 17:25 -
Format for archiving camcoder video?
By Arctirus in forum Newbie / General discussionsReplies: 3Last Post: 16th May 2008, 22:54
