I have been having the weirdest things happen with VDCEASY. I have normally used Imation 80 minute 700MB CDRs and they always record at the correct speed (48x). I just recently bought some Verbatims and they would not record but at 8X. So I took those back and exchanged them for Imations again and now these Imations are only recording at 8X. I have been puzzled about this so I tried a FujiFilm 80 minute 700MB CDR and it records properly at 48X. I also tried a Memorex 80 minute 700MB CDR and it also records at 48X. What gives here. I have always been led to believe that Imation made a good product. Verbatim (okay but not up there with the best)...so who makes the best CDRs anymore. I will end up taking these Imations back and replace them with something that records at the proper speed. Anyone know anything about this???
Dan
Don't be so quick to judge.
maybe it's just a cockup at the factory with printing the right speed on discs(pretty big cockup, i grant you) but just a cockup all the same. -
Or, it could be a bug in CDRDAO...
Regards.Michael Tam
w: Morsels of Evidence -
Typical symptoms of older software. Your burning software doens't recognize the CDR disk ID, so it defaults to some value for burning speed. I had this happen with new disks and older Roxio 4. Try Nero 6 and see if they burn at speed. It can also be a firmware issue with your burner ($40 burners don't always recognize every media type).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
sure its not your burner thats limiting the speed? vcdeasy doesnt really have much influence except to burn at lower than the top speed.
The electronic components of the power part adopted a lot of Rubycons.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 23:30 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
