I was looking for some reviews on this puppy. I searched the forums, and I could only locate, "their tech support sucks" but nothing on media compatibility or stability of DVD -/+ burns, etc..
Comments?
Feedback?
This is the Hi-Val retail boxed -/+ Dual media drive available at CompUsa for $159 after rebate?
Good?
Bad?
Pros?
Cons?
I know their CD-R/RW drives suck. I suspect the drives they sell are the ones that failed on the line and were reworked. Basically like Grade C media that Hi-Val sells under its media.
RG -
This is unfair. You will find that the HI-VAL recorder is just an repackaged major brand. The big problem is that the OEM drives will not be constant and will be changed upon market conditions. You will probably be able to get a good deal if you are careful. Here what you should do - buy from a merchant that accepts returns - find the OEM for the drive you have purchased and if this OEM is acceptable, keep the drive.
IMO, there are few unacceptable OEM DVDR/W manufacturers. -
The NEC 1300a 4x DVD+/-RW drive is a better deal at $114 here http://avlogic.com/product.cgi?code=18030059
I believe that Hi-Val filed for chapter 11 or 13 last year so if they are back then they are just now coming out of bankruptcy.
Connecting SATA hard drive in IDE PC
By alegator in forum ComputerReplies: 17Last Post: 13th Apr 2010, 14:00 -
Using Laptop (IDE) Hard Drive in New Desktop?
By ron spencer in forum ComputerReplies: 3Last Post: 30th Jun 2009, 13:21 -
DVD Player With IDE Drive
By wulf109 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Jun 2008, 15:44 -
board not finding ide drive
By 123fish123 in forum ComputerReplies: 7Last Post: 13th Jun 2007, 16:19 -
IDE + Sata Drive ?
By StoneColdWhat in forum ComputerReplies: 4Last Post: 17th May 2007, 15:50
