  1. DVD Lab comes with several background in it, but I was curious, can you make your own backgrounds for it?
    It looks like the file extensions are .tmb and .bkg. Anyone got a clue if you can make your own or where can you get more at?
    Thanks!
  2. Member Roderz's Avatar
    Jul 2003
    the armpit ofthe Midlands
    Rigtclick on backrounds and import a file, accepts --->*.jpg;*.png;*.bmp;*.tga;*.psd;*.pcd
  3. Member GordRocks's Avatar
    Alberta, Canada
    I know that you can drag (from the File Browser or Windows Explorer) any .jpg file into the Backgrounds Bin and you will be asked if you wish to copy it as a permanent background. Then you can use that image as a background. I haven't tried any other image formats.
    .....Gord
    Outside a dog a book is man's best friend. Inside a dog it's too dark to read.
    ------------ Groucho Marx
