I have Pinnacle Studio 8 and am having trouble with it. It says I have a corrupt or missing file. The name of the file is DEPOP.DXR
I have tried re-installing it and I get the same thing. Does anyone have this file they could send me so I can get back to capturing?
My e-mail address is john@lt1intake.com
Thanks so much!
Is it corrupt or is it missing?
Have you tried contacting Pinnacle for a copy? -
Uninstall...Regdelete...Reinstall.
http://webboard.pinnaclesys.com/read_forums.asp?WebboardID=1&SectionID=143&lng=1&Produ...DocTypesID=181Geronimo -
It is missing on the desktop. It's not on the CD either. Must be in some compressed file somewhere.........Originally Posted by bugster
I have e-mailed Pinnacle but got no response........ -
Your best bet would be to do what redd says. Just uninstall and reinstall. Even if you find a copy of the file, unless someone at pinnacle gives it to you or says its ok, I would not trust it. At least until you know what the file does.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
That file goes in the "Guided Tour" directory of Studio 8. Try re-installing using the "Custom" install option and deselect the Guided Tour. You really don't need it anyway.
I emailed you the file if you'd rather go that route but I'd be willing to bet you're missing other stuff as well. -
My experience with Studio 8 is even if you had every file with a perfect install all you could expect when you run the program is a complete computer lockup requiring a cold boot.
My experience with Studio 8 is, as I have every file, a completely flawless 'capture' (DV) and perfect output with superb effects and transitions.Originally Posted by Bob W
Every time.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
Configuration System File Missing or Corrupt. PC won't boot.
By jollyjohn in forum ComputerReplies: 7Last Post: 23rd Jun 2010, 14:24 -
ShellManager corrupt or missing
By princessmarston in forum ComputerReplies: 2Last Post: 29th Jun 2008, 20:05 -
Missing or corrupt file in Win2k
By bevills1 in forum ComputerReplies: 8Last Post: 10th May 2008, 21:43 -
Pinnacle Studio 11
By fjmr in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 04:44 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 19:53
