Great....one thing I noticed with DVD Decrypter which could hopefully be fixed in the next version is the fact that when you set the "delete incomplete files" to "NO"..DVD DECRYPTER can memorize that setting.
The way it is currently...if you change that setting to "NO" DVD Decrypter will revert back to "YES" on its own after you close out or reboot your PC. When I want to check settings of a specific VOB..I usually just rip 10% of that Vob..stop the Rip process and then check it. But being that DVD Decrypter always changes the option back to "YES"...I have to make sure I constantly change it back to "NO."
But that is obviously a minor thing for such an amazing proggy.![]()
