Can someone please explain the following:
I did the vcd header trick on a mpeg-2 file of 824megs, but after the simple multiplex the file got over 1gig, while normally it gets smaller then the source file.
Did I overlook something?
Grtz,
Don
Doesn't anyone has any ideas?
Maybe too litle info. here's what I did:
1) downloaded the movie as bin/cue file.
2) used daemon tools to extract the mpeg file
3) used tmpgenc tools to multiplex the mpeg file
4) result a file much larger then the source
I did lots of conversions like this before, but this one just doesn't work.
Still hoping for suggestions....
When you used tmpgenc tools to multiplex the mpeg file did you set prog type to 'MPEG-1 Video-CD (non-standard)' ?
Yes, I choose Video-CD standard.
p.s. did you know cereal was invented to prevent masturbation..... -
You should probably do "VCD MPEG (non-standard" or something like that....
1 GB? wow.
KvCD to vob
By natty in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2010, 15:37 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21 -
KVCD
By Bat21UK in forum Authoring (DVD)Replies: 7Last Post: 22nd Dec 2007, 15:31 -
2 hours plus on one kvcd - how?
By t41 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 11:08
