Hi,
I have an older P111500 on my network which I will be using a DVD writer on. The MOBO is a Intel Seattle 2 with an ATA33 controller. The system also has an ATA100 Promise card for video drives, as well as firewire. (USB 1 only)
I have three options for connectivity: Firewire, ATA100, or the DMA33 on board controller. The ATA100 is not a preference as it is pretty used up. I will probably use the firewire with an external writer, but my question is this: Excluding the limits of the processing power of this system, would there be a difference in the performance of the writer between using the Firewire, and the DMA33 controller, if I choose to install an internal unit? In other words, would a DMA33 controller necessarily be a bottleneck for read-write speads of any drive or media, or is the unit independent of this? Also, if I would use the ATA100 card, are there any known issues? Thankyou.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Milt
DMA33 is perfectly fine for any dvd writers out now -- performance would be the same as firewire ..
Small Notebook with Firewire Connectivity
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2009, 13:56 -
Looking for something like the WD HD, but would like net work connectivity
By Jhon in forum Media Center PC / MediaCentersReplies: 7Last Post: 18th Apr 2009, 08:05 -
Troubleshooting DV camcorder connectivity
By JohnnyMalaria in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 16th Mar 2008, 02:25 -
Internet Connectivity Problems
By RKelly in forum ComputerReplies: 4Last Post: 19th Feb 2008, 11:28 -
usb connectivity in DVD Rec
By nirbhayn in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2007, 18:30
