Does anyone know how you can manually select the actual recording speeds in RNM 4.50 ?
I ask this, because if I select Minimum speed, it still burns discs at 2x or 4x dependent on the media. I know that you can select them manually, because I have seen screen shots which have the option in them, is it a version/feature matter, or is it dependent on the fw of the Burner ?
below is a screen shot in the full application, not the wizard. There is a dropdown box.
Jim -
Actually that's after a PX Engine update - the base install of RNM 4.50 only has "minimum, normal, and maximum" for speeds - very confusing.
- Gurm
Is it possible to copy or record 3hours vhs recording in less time
By nusratjaveid in forum Newbie / General discussionsReplies: 6Last Post: 25th Oct 2013, 08:50 -
Syncing DV footage with external audio recording - different speeds?
By mjl5007 in forum EditingReplies: 5Last Post: 20th Oct 2011, 05:19 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
Movie speeds
By drmrsolds in forum Video ConversionReplies: 8Last Post: 16th Nov 2009, 06:35 -
Erase/record new program from *middle* of previous recording?
By NoahsMyBro in forum DVD & Blu-ray RecordersReplies: 10Last Post: 18th Nov 2007, 12:55
