isn't NTSC better with it's higher framerate??
8)
Results 61 to 68 of 68
"Duchess"
??Yes we may get more money but our costs are very much higher ??
That's why I moved to Australia, to sunny Queensland to be correct.
Sounds like the Northern Hemisphere has gone to the dog's.
You get only benefits (if ever) from a higher framerate, if the footage was shot with that framerate.As most movies were/are done with 24fps, you have to fake around 6 frames per second to get 30fps.This is not better (I believe it's worse) than fake jsut 1 frame per second.Originally Posted by Amaro
I have MANY Region 1 and Region 4/2 transfurs of the same film, and ALL of the NTSC (Never The Same Colour) look like SH|T (in comparison). My dvd player outputs a signal which is NTSC to my tv, which can display NTSC, and it still looks lilke sh|t. NTSC is jerky, PAL is not. NTSC is less difined, and PAL looks sharp and crisp.Originally Posted by FulciLives
Do ur reasearch A$S HOLE -
That's why PAL just speeds up the film from 24 to 25 fps. The whole idea of adding frames is just daft. Why do you think that HDTV is going progressive scan? Interlaced pictures gives more fluidity to movement, but adding lots of duplicate frames doesn't.
In all seriousness, with its bad frame rate, poor colour response and low resolution I can't find a single positive thing to say about NTSC. -
Actually, You don't have to fake any frames with a PAL transfur, with the 4% increase in speed.Originally Posted by Dragonsf
+Originally Posted by energy80s
I can. No increace of speed, no change in pitch
thats it!
Colour correction of a NTSC VHS captured via PAL Equipment
By alesco in forum RestorationReplies: 24Last Post: 22nd Jan 2012, 15:46 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47 -
Would NTSC DivX play on PAL equipment?
By videoboy2008 in forum Newbie / General discussionsReplies: 4Last Post: 10th Apr 2008, 03:43
