I want to run two monitors simultaneously
are there any ways to do this??? I want both monitors showing the same thing at the same time one for my staff the other for my customers.
Some PC video cards come in Dual head versions. Depending on how you set up the driver you can either have two identical displays or one large display across two monitors. Check out the Matrox and Nvidia dual head cards.
Moved to the Computer Forum -
plus, depending on your OS, you might just be able to drop another video card in your system and configure it, rather than a 2-head device.
I know that WinME and up support two-video-card display options, and I've done it with a decent AGP card and a leftover PCI with no problems.
(in fact, if I can clear some desk space, I'm going to do that again with a 4mb vid card I picked up for $5 at my local computer surplus store...)- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I am running dual monitors at home and work. Two cards at work, one at home. If you are running XP, piece of cake. Almost impossible to screw up.
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 02:06 -
Dual band or not?
By yamatosoul in forum Video Streaming DownloadingReplies: 3Last Post: 30th Nov 2009, 18:35 -
Dual audio help
By psyduck215 in forum Authoring (DVD)Replies: 3Last Post: 14th Oct 2008, 20:05 -
Dual Core vs Dual Processor
By kissvid in forum ComputerReplies: 59Last Post: 17th Jun 2007, 11:27
