THANKS "Vejita-sama" for your support so far. But the problem isn't solved yet.
Maybe somebody can help me futher.
I am in Europe so I have to use PAL.
I capture with VurtualDub format for SVCD resolution 480*576 (that's what advised).
Converting with TMPGenc2.0 for SVCD.
Settings VIdeo: CBR, 2200 kb/s,Interlace, high Quality.
Advanced: Source= non-interlaced, source aspect ratio=4:3 625 PAL, video arrange mode=full screen (keep aspect ratio).
Well, the MPEG-output is a picture that is out of propotions at the PC-screen (not in 4:3 proportions, just like the input-AVI was. Looks like 3:4), but that is normal as far as I understand.
I burned the MPEG with Nero 5.5 (SVCD, with menu option) on a CD-RW. The SVCD played on the stand-alone DVD/VCD-player, but the TV-screen also showed the "wrong image size". It was still not full screen and the image had the wrong proportions between highness and width (too high). Can anybody help me? Any idea what's wrong or what I am doing wrong?
h.hanssen@zonnet.nl
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I think the error is source aspect ratio.
If you capture 480x576, it's not 1.333, it's 0.833, so you can't tell TMPEGEnc to keep aspect ratio!
You can try to set the source to interlaced (it's true for a TV capture!) (so tmpeg take the source as 480x288 non-interlaced, 25fps, 50field per second)
Or can try to set source aspect ratio 1:1 vga, then in the video arrange box choose custom size and set it to 480x576.
Hope this helps.
Bye,
MarioB79
<font size=-1>[ This Message was edited by: MarioB79 on 2001-10-08 02:46:37 ]</font>
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
