Hey Guys,
The other night I made a back up of Identity using a fuji dvd +rw. Came out great and my panasonic rp56 recognized it with no problem. So I figured I was good to go. So I tried burning to a dvd +r and it didn't recognize it. I tried to play it on another player..same thing won't play. So I thought dvd x copy express was junk so I decrypted with dvd decrypter and then used dvd shrink to convert it down to one dvd +r. I burned with nero and I am still getting coasters. According the dvd compatibility my panny should play all the dvd formats and i read comments where people are able to. Any help would be appreciated on how to make trimmed down back ups of my movies.
Thanks..
How did you burn the DVD+RW? Did you do the exact same thing with the DVD+R? Make sure your player will play DVD+R, some players will play DVD+RW and not DVD+R and vise versa.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
we couldnt get many dvd+r disks to play in this machine -- same as a rp-62 , doesnt play dvd+r well at all ..
no problems with dvd-r and dvd+rw though
the rp62 manual even states it doesnt support dvd+r but it also says it doesnt play svcd - which it does perfectly well .. go figure .
you will just have to try different media or burn a dvd-r"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
ok thanks...i was wondering about the dvd +rs. I wondered why it played fine with the +rw and not the +r. I am going to try again with the rw and see what happens. I did the process the same for the movies. I used dvd decrypter and did the whole movie. Then I used dvd shrink 3.0 and re-authored the dvd. Then I burned with Nero 6.0 using the dvd-video template. That should work, shouldn't it?
Convertxtodvd Burning problem
By alicy in forum Authoring (DVD)Replies: 8Last Post: 18th Jan 2010, 15:36 -
Problem with burning.
By googoodolls in forum DVD & Blu-ray WritersReplies: 7Last Post: 12th Dec 2009, 07:20 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
burning problem on new drive
By yogart in forum ComputerReplies: 16Last Post: 11th Jun 2007, 13:40 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
