Hi,
I am trying to convert DivX avi movies using ac3 codecs as well as other codecs not supported by TMPENC program.
After installing the codecs I can view it in the mediaplayer in AVI format but converting it to mpeg doesn't work at all for the sound. I get perfect picture but no sound ?!?!
How to make this work / what other programs are available ?
/Daniel
you need to DEmux the sound the AVI first...then convert the AC3 to MP2...i receommend using Azid to convert AC3 to wav, then toolame to go from wav to MP2.
And what do you recommend for DEmuxing the AVI?
thanx,
La Torcia
I think TMPG will do it, using the "mpeg tools"->"demultiplex"...I think, I dont know, I dont deal with divx....and may
I found that if you use nero to encode a Avi to mpeg to make a vcd, it turns out pretty good.
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 04:55 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
Audio doesn't play in AVI files, although AC3 codec IS installed
By DVantrease in forum Software PlayingReplies: 2Last Post: 16th Jan 2009, 18:57 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24
