This might be a dumb question ... I have MPEG2 files I've captured from VHS using Adaptec Videoh and Sonic MyDVD. I want to burn these to a DVD using RecordMax and not the MyDVD burn function. Do I have to do something to the MPEG file to make it playable on a DVD, or can I just make a data disk and burn the MPEG file directly onto the DVD?
I use TMPGEnc DVD Author and RecordMax
Basicly you open that file(s) you want on the DVD, add menus if you want, and then it will create the directories Audio_ts and Video_ts. Run RecordMax and make a data disk, click on the add files and add the Audio_ts and Video_ts directories. Click the burn button. Thats it.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
MPEG2-->MPEG2 Crop + Resize
By wincrazy in forum Newbie / General discussionsReplies: 26Last Post: 24th Jan 2009, 01:30 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45
