Could someone please advise
If I want to include 5.1 surround sound do I have to include the ac3 6 channel.
Also does the ac3 2 channel just give conventional sterio
? what is DTS
You got it! Dolby Digital (or ac3) is the default sound system for DVD. 6 channel is 5.1 and 2 channel is stereo! DTS is a rival 5.1 sound system to dolby digital which has a higher bit rate and (I think) better quality. It's the best "extra" a disk can have in my opinion. But if you don't listen in 5.1 and have no plans to upgrade, lose it and use the extra space for better picture quality.
Hope this makes sense, anyway! -
Thanks bobbublaze
for the help
If I were to only use the 6 channel then, and forget the two channel that would still work and give me just sterio if I didnt have the 5.1 surround sound decoder
is that correct, sorry to sound vaugue
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 05:18 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
