Ok, I have 26 AVI files currently encoded in xvid. I want to re-encode these mpeg2, DVD compliant files to author a DVD. The AVI's are compressed so that they all fit on one DVD, but im noticing that when I tried to use Canapus Procoder to convert them (With the most compressive settings), the best i can do is put 3 episodes on one DVD.
What program is best for reencoding these to DVD compliant DVD's with teh best compression so that i dont have to use more than 2-3 DVD's for the whole series?
Thanks again
Results 1 to 10 of 10
Newbie Maximus
how long are the files? (sounds like a tv series (26 files), but i'm not advocating warez, so I hope it's not) I usually just encode to a xVCD at like 2000 kbps and then author to a DVD using TMPG DVD Author.
I can fit about 12-13 22minute episodes per disk and the quality isn't half bad. -
Fansubbed Anime -- unreleased in teh states.
What software are youusing to do that? 13 eps per DVD would be optimal
What im really asking is, what software ar eyou using to convert the AVI to MPEG2 and have control over it to reduce teh bitrate enough to get that many eps on a DVD?Newbie Maximus -
I use TMPGenc to encode at VBR with a minimum of 300, average of 2000 (or whatever it works out to be for your source, just use https://www.videohelp.com/calc and select your ouput as a DVD disk, then put the total time of the episodes plus about 10 minutes for extra padding security), and maximum of 4000.
You will have to first load the VCD NTSC template, then load the unlock template so you can alter the bitrate in TMPGenc.
You SHOULD first convert the audio to a dvd standard of 48000hz using something like Goldwave, and then encode as Elementary Streams (ES) then take the resulting files into TMPG DVD Author, make a snazzy menu, and let it go to work.
to do all this you need 3 programs.
Goldwave to extract and change the frequency of the audio
TMPGEnc, load the video file, load the extracted audio file, load the vcd template, load the unlock template, set your bitrates, make sure it doesn't resample the audio to 44100, set it back to 48000 if you have to.
And TMPG DVD Author. -
Thanks, that alot of help. Where shoudl I go if I need specific help while trying to figure this out? Any guides for these peices of software available?
Newbie Maximus -
Tons Just look to your left Under the HOW TO section, pay particular attention to the CONVERT section.Originally Posted by Hoagie_one
you rock, thanks again. I should actually look around befoer i start asking Q's, lol
Newbie Maximus -
There's a lot of people that could use that advice!Originally Posted by Hoagie_one
"Art is making something out of nothing and selling it." - Frank Zappa -
An why would you want to do that, avi compression schemes (divx, xvid) are very different in terms of bitrate requirements than mpeg-1 or 2.Originally Posted by g_shocker182
Which Mpeg2 compression codec?
By yugurya in forum EditingReplies: 6Last Post: 20th Jan 2012, 01:35 -
Compression technique/standard used in MPEG2 Transport Stream
By digitalmystic in forum Video ConversionReplies: 1Last Post: 1st Nov 2010, 07:50 -
MPEG2 Compression - Question
By b1tbull in forum Video ConversionReplies: 3Last Post: 2nd Jul 2010, 04:14 -
DVD Shrink compression method question
By SCDVD in forum Newbie / General discussionsReplies: 5Last Post: 14th Jan 2009, 13:42 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 09:45
