I use cyberlink's Power VCR II to capture tv programs and everything but why does it split the captured program into more then one mpg file.
PowerVCR II has a registry entry "MaxRecSizeMB" which can be tweaked.
The default setting is hex 258 or 600 (decimal) MB. You can set it to what you want.
Make Sure you change it in 2 places.
do a regedit do a find on "MaxRecSizeMB" change the Decimal to what you want do a refind and change the next "MaxRecSizeMB". -
Adding to NYPlayer..go to HKEY_CURRENT_USER->Cyberlink->PowerVCR and right-click on MaxRecSizeMB and select Modify->Decimal and enter 4300 or whatever.Do the same for HKEY_LOCAL_MACHINE.
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 23:15 -
Does anybody have Power DVD v7.3?
By Sean_ve99 in forum Software PlayingReplies: 7Last Post: 11th Dec 2007, 01:12 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02
