I just paid for a "commercial" version of vcdeasy because I wanted the ability to do chaptering in VCD. Then I got to thinking that I paid $20 just to do chaptering. I use SmartRipper for ripping, DVD2AVI for frameserving, tmpgenc for ending, Nero for burning, so nowhere do I truly need VCDEasy. So what else is VCDEasy good for? I know it can burn the CD, but I have Nero already. Somebody, please, tell me I didn't spend $20 just to put chapter points on a VCD!
Andy
You have interesting priorities.
I usually decide what something is good for before
I buy it, instead of after. -
Its good for making (re-encoding, authoring and burning) SVCDs from DVD movies.
Sam Ontario -
No you don't truly need vcdeasy, but it is probably the best program for creating menus and and other interactive things that you can find out there that will do vcd and svcd. Phillips VCD toolkit is probably better, but it only works for vcds and is a lot harder to learn. If you were to ask me you got a very good deal, that is if you use it.
@Sam
It doesn't reencode dvds. It's best for authoring as the burning engine (CDRDAO) is not compatible with some cd-r drives. If you support VCDEasy the author has expressed that he would like to add a better engine like the one in CDRWin, but that costs money. -
Originally Posted by FOO
Michael Tam
w: Morsels of Evidence -
I use VCDEasy for chaptering my VCDs. I really like the Interactivity options.
I like the way VCDEasy handles clips. You don't need to join them as VCDEasy navigates smoothly from one to the next. When I did this in Nero, I got an annoying beep between clips.
I use VCDEasy to revert .dat to .mpg when just renaming doesn't work.
I use VCDEasy to make MPEG stills for my menus.
I use VCDEasy to burn because I like the musical sound it makes when it finishes. :PDon't squat with yer spurs on.
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 09:41 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 03:18 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Looking for some good instrumental music that would be good for football.
By ingeborgdot in forum AudioReplies: 8Last Post: 26th Nov 2007, 21:18 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
