Is there a program that will let you re-format a dvd-rw? I can create nice dvd home movies using Pinnacle Express but somehow the dvd-rw was changed to an audio format and shows 1.99 gigs available and it's a 4.7 gig dvd-rw. I can only erase with the PrimoDVD utility program.
In Europe the Pioneer drive ships with VOBs InstantCD/DVD. This has a button to erase a CD-RW or DVD-RW disc and works fine. However, you have to load the program for creating a new CD/DVD before you see the Erase button.
I would presume Primo has the same button. Insert your DVD-RW disc, choose to create a DVD disc layout and look for an Erase or reformat button on the toolbar.
Suggestion needed from DVD to HD
By onlygk in forum Newbie / General discussionsReplies: 4Last Post: 20th Nov 2010, 05:44 -
Dvd hacks needed
By poisonivy4 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Jun 2010, 10:38 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 22:23 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
