Ok Im doin vhs backups and recording off direct tv.
I read lordsmurfs tutorial and he says to use 352 instead of 640... why? doesnt that lower the quality? Im backing up vhs tapes for a video store so I need the best quality. please explain! Im using a ATI radeon card
thanks
VHS resolution is only about 352x240 (NTSC) so capturing any higher would be a waste of time
the reason you capture at 352x480 is so you capture both interlaced framesYour Nickname Was Never Ace, Maby Ace Hole -
If you are going to put the video on CD or DVD then definatly capture 352x480,you will get no or few dropped frames.Capturing 640x480 is ideal for viewing on PC and have a fast CPU.
640x480 (NTSC) isn't valid for DVD, but 352x480 is. I still capture at the highest resolution I can, then resize to the desired resolution, just because I've found that the end file (after resizing) comes out looking better then if I capture at a lower resolution.
Just my thoughts."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073
Converting 720x480 to 352x480
By Regor21 in forum Video ConversionReplies: 8Last Post: 9th Mar 2011, 11:34 -
Force 640x480 4:3 on AutoMKV?
By Tri.Moon in forum Video ConversionReplies: 1Last Post: 24th Feb 2010, 12:52 -
720x480 or 352x480 ?
By StoneColdWhat in forum Video ConversionReplies: 7Last Post: 7th Aug 2009, 09:16 -
AVCHD at 640x480
By PuzZLeR in forum Video ConversionReplies: 9Last Post: 24th Apr 2008, 14:49 -
720x544 vs 640x480
By gigantibyte in forum Video ConversionReplies: 31Last Post: 15th Jan 2008, 10:14
