I've been doing a lot of capturing off of TV lately, but have been disappointed with the quality of my reencodes because to get a 2 hour program on a DVD, I have to use a bitrate around 4000. I'd like to capture at 1/2 resolution so that I can use a higher bitrate and hopefully get better picture quality. Is there a capture program that will allow me to do that? I have VideoStudio, and a couple of other programs that have the ability to capture, but haven't been able to. Could someone offer some assistance?
Aaron,
If you try MainConcept 1.4 I believe it will capture at 352x480. Actually the "capture" is DV, but it will on-the-fly encode to 1/2 horizontal resolution. -
AFAIK, when capturing from any DV device, be it a camcorder on pass through or a dedicated capture device, you are limited to full D1 resolution capture (720*480/576). After capture you can encode to mpeg in 1/2 D1 and that should solve your quality issues, or at least help.
Is there a 3CCD Digital 8 camcorder?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 21st Dec 2023, 23:32 -
DVD Quality Resolution for Panasonic SD camcorder
By pannyuser in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 28th Mar 2009, 17:06 -
8mm to Digital - Capturing w/ DV Camcorder
By tripecac in forum Capturing and VCRReplies: 61Last Post: 9th Jul 2008, 19:51 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 13:47 -
resolution on movie nero digital
By krain_l in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2007, 00:49
