Hi,
is there any way of adding mp3-files as selectable in an dvdr?
Whant to make a dvd that holds both video and soundfiles.
Regards
Would that be for playing on a PC? If you make a DVD with all the necessary video files and structure you can still store any files (space permitting) in a separate folder from the VIDEO_TS & AUDIO_TS folders.
It should play the DVD with menus, navigation and videos properly in a standalone player or PowerDVD/WinDVD and the other files (MP3s) can be accessed from PC.
Is that what you're wanting?There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Hi,
no, i want to access these video and soundfiles on a standalone player.
Regards -
I don't think that can be done. Unless you had some kind of highly specialised player that I sure don't have. :cD
To be within DVD standards, you can not use MP3. You'd have to use the audio as a track for a still image (or series of images or black) and make that an mpg, which would take much more space.
Maybe? Time to take a peek at DVD specs and see what's possible/what's not. :c) Top left corner there.There's no place like 127.0.0.1
Audio mix/false advertising?
By takearushfan in forum Newbie / General discussionsReplies: 10Last Post: 27th Sep 2011, 21:31 -
Dual Audio Mix in in a VOB File.
By niteghost in forum AudioReplies: 5Last Post: 31st Dec 2010, 07:27 -
DVD - Mix Audio from two captures? What is the simplest solution?
By ChasePlace in forum Newbie / General discussionsReplies: 0Last Post: 29th Dec 2010, 12:26 -
Another post that's a mix of Audio, Editing and Restoration...
By takearushfan in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2010, 03:00 -
Easiest way to mix different audio into .avi video file?
By BertRito in forum AudioReplies: 4Last Post: 21st May 2008, 23:57
