  1. I have downloaded a few video files with the MPEG and AVI extensions. I have NERO 6 but it doesn't support these types of extensions for burning dvd video files. What should I do?
  2. Member Devanshu's Avatar
    May 2003
    If your files are mpg2's...you're in luck. You dont need to convert those. If not, then convert your files w/ tmpgenc, run them through an authoring program, and burn away. For more details...check the guides on the left.
    Apr 2002
    The State of Frustration
    It really does not matter if your files are MPEG-1 or -2, or AVI. The Convert section should have a guide to help you. Click here.
    Hello.
